washer agitates and spins - won't fill
The machine won’t fill with water or run during any fill/rinse cycles. It will agitate and spin. I swapped out the lid switch, cycle control switch and water level swith, but to no avail. However, the switches I used came from an old parts machine of the same model. I just want to know what part is suspect so I can replace it.
Most likely the problem is a bad water level switch. Check for continuity between the terminals "V" & "P", and "V" & "T". It suppose to be closed circuit between "V" & "P" and open circuit between "V" & "T" when there is no water.
  • The part number for the water level switch is AP3019752
Hey Gene,
Thanks for the reply. I had already swapped out the water level switch. It was actually the water inlet valve. Seems to be working fine now.
Bill
Bill,
You are welcome. I’m glad you were able to fix it.
