Washer won't fill
Our washer won’t fill with water and will start agitating instead. If I mess with the water level switch I can sometimes get it to start filling. Will replacing the water level switch fix the problem?
It sounds like you are on the right track. Part number 3366847 or AP4567828. Hope that helps.
