Washer arms don't spin
I have a Whirlpool dishwasher, model # gu1200xtkq0. It fills with water, but when the cycle starts the washer arms won’t spin. It seems like there’s not enough water in the washer. I’ve added more water so the float is all the way up but still the arms don’t move. If I cancel the cycle it drains properly. Any ideas as to what could be wrong. Any suggestions would be greatly appreciated. Thanks. GEWOZ.
Gene said:
If the wash pump runs but the spray arm does not spin - there is not enough pressure in the wash system.
Remove the water feeding tube and the pump cover.
Remove the inlet protector (#8 on the pump & motor break down diagram) and check the chopper for a clog.
Thanks Gene. I’ll let you know how I do.
Check the thermostat inside the icemaker.
— Begin quote from Jake Finch;36796
Can someone tell me where does the 115v come from that powers the icemaker plug on the right side of the icemaker. By that I mean where does the incoming power on the black w white strip and the white wires feed from (115v)? A terminal connection? A Wiring bundle with no fuses? Where does the 115v break off to the various devices in the whole refriderator?
Have you had a resolution yet?
I had only 30vac when I check for power. Replaced ice maker and fix problem also.
dave
Hi !
As stated in the title. I first noticed the refrigerator side was not cold, then I noticed some ice on the back wall of the freezer side.:frowning: After reading the forum, I read about the air passage way from the freezer to the refrigerator. I checked that this morning and found it closed.:eek: I opened it back up, so my question is…what do I do now?:confused:
Will the freezer back wall eventually thaw? Do I need to reset the temperature settings on the freezer and refrigerator?
Thanks!:slight_smile:
— Begin quote from gewoz;12594
So did that fix your problem? I am having the same issue with my dishwasher same model. I’ve checked the filters and am thinking there must me something wrong with the impellers for the wash part of the pump?
I am having the same issue with my whirlpool gu1200xtls3.
Everything works except the arms spinning. I took it apart and checked the screen and the impeller. No issues
Any other suggestions?
— Begin quote from Oneillb;763414
I finally discovered the recirculating pump on mine was out and based upon the cost and finding a deal just replaced my dishwasher.
