Washer makes loud roaring sound in spin. Hope someone has fixed one of these, I never did. Thanks in advance. This is a Cabriol washer
— Begin quote from richappy;385140
Rich,
Yes, sounds like the tub bearing assembly is worn, badly.
You’ll need to order the outer tub assembly, it will have the bearings, seal and drive shaft assembly in the tub kit.
It’s not that hard a job to perform, more cumbersome and frustrating, than hard.
Good Luck,
Thanks Joe, unfortunately over $300 in parts will effectively terminate this washer.
— Begin quote from richappy;385195
Rich,
Correct, I didn’t do too many OOW or service contract repairs on that unit,either.
