When cycle is finished clothes are still dripping wet. Water is draining from washer. Sometimes I can put a light load in and it will spin just fine but it must be a very light load. What is the problem?
The problem can be a bad drive block (#17 on the [B]diagram, a bad basket drive (#1 on the [URL="http://www.appliancepartspros.com/partsearch/model.aspx?model_id=503123&diagram_id=28289167)) or a bad clutch.
You have to remove the washer cabinet
http://www.youtube.com/v/OlAFQnkapLM&rel=1
to access these parts. The instructions are attached.
You can find more useful information in one of our previous threads: http://forum.appliancepartspros.com/washer-repair/373-not-spinning.html
Here are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?model_id=503123
