I just replaced the gearcase, brake/drive tube assembly, and clutch band ring. Everything seems (or sounds) normal. I think it was a successful repair… but now. The tub wont spin at first… the water is draining out but no spin, then I open lid switch and close again and the spin behaves normally.
More specifically… Ive got the control panel flipped up and the lid switch re-routed. Okay so then I should say… the clothes agitate as normal, then when its time for the spin cycle… everything stops (for safety of course) and I walk over to the lid switch and activate, then comes this problem… drain, but no spin. Im holding the lid switch for 10 sec or so(even for 1 second or so) and then let go of switch and press again. It spins up normally with healthy acceleration.
At one point, I can’t specifically say when. The darn thing started to spin with the lid switch up!!! Im thinking this is a logic issue? I havent figured out the weird sequence of press/release lid switch to make it do this, but all-and-all, I can tinker a normal wash cycle. OR could this be related to clutch/drive cam/drive tube stuff? Any thoughts would be greatly appreciated.
