washer wont spin unless u open and close lid
kenmore 70 series washer goes though all cycles fine but when ir goes into rinse cycle it wont spin it drains water out but if u open and close lid it will spin ive replaced lid switch still same thing ive bye past lid switch
and when it goes into rinse cycle it starts to spin and stops right away and wont spin till u open lid again dont think its the timmer cause it goes though all the cycles it just wont spin during rinse or spin cycle it
agitates fine need help cant seem to find anyone that can answer this post!!!:frowning:
Hi.
Based on the information you provided the timer need to be replaced.After washer drains out the water the timer pausing fora few seconds allowing the transmission to engage in the spin mode.
By opening and closing the lid you are pausing.
The timer 661636
Post the results.
Simon.
so i go out and spend $138 total for timer
now i still have same problem plus now out $138
ok replaced the timer ( $138 timer ! )
replaced lid switch ($24)
replaced clucth assembly ($51)
still have same problem every thing works great till it gets to rinse or spin cycle it drains ok it trys to start to spin then stops like the breaks stopped it
but if u open lid and close it it then starts to spin !!!
help please not much more i can replace if i new i was going to be $200++
into it i would have just bought new!!:confused: :confused: :confused: :confused: :confused:
Operate the machine with the cabinet removed and lid switch bypassed. The washer should fill, go into agitate, at end of agitate mode, motor pauses, starts up again in reverse direction. At this point, it should be draining and the clutch hub should not be rotating. Observe the clutch hub near end of agitation mode to be sure it doesn’t start rotating when drain mode starts. After drain, motor should pause again for a few seconds. When it starts back up again the clutch hub should be rotating.
If the motor doesn’t pause after agitation mode and drain mode, it’s a timer issue.
If the clutch hub is spinning and the basket is not, it’s a mechanical issue (clutch, brake, tub drive block, clothes between inner/outer tub,…etc.)
If after drain/pause/restart for spin, the clutch hub is not spinning, it’s a gearcase issue.
Eric
:smiley: works great thx for your help
— Begin quote from fairbank56;780034
Eric
What did you do to get it fixed???
yes thx very much
HI.
Do you mind to share with us what did you do to fix the problem?
Simon.
replacing clutch seed to fix my problem after it drains now it starts to spin
so the clutch was my problem thx 4 the help
Great explanation and advice! After reading up on this and what "Neutral drain" means, I discovered my no-spin "problem" is perfectly normal. I was expecting the tub to start spinning as soon as the drain phase started after agitation and after rinse. In reality, the tub is supposed to drain first without spinning, pause, then spin.
Moral of the story: Don’t expect the washer to spin until after the tub is fully drained.
