Washer drain pump lift
I was wondering about how high would the drain pump on my washer pump my water out? My washer is in the basement and now drains in the basement drain that goes outside and I’m wanting to attach it to a pipe that drains to my city’s sewer where my other water drains too. The pipe I’m wanting to connect to is about 6 ft.high running along my basement wall and I’m needing to know if I can run my discharge hose to that. The washer is sitting by the wall where the pipe is. Thanks
That should be fine, 8’ is maximum height.
Eric
Thanks for the reply; It’s actually around 4 1/2’ ; so I should be ok then? Thanks
Didn’t realize a replay had been made.
