Washer fills, agitates, drains, spins, won't fill to go on to rinse cycle.
Kenmore washer will fill, agitate, drain, then spin through the first cycle. Then it stops and will not go on to fill again to rinse. If it is turned off and back on it will usually jump straight into the spin cycle, but does not fill first. It is the same for all wash settings. Fill, agitate, drain, spin, then does not move on. Any suggestions?
Since it will go through the wash and first spin cycle ok, that suggests the mechanics of the machine are ok, and that you should try changing out the timer to see if that fixes things.
Kenmore washer was not moving on to rinse on standard setting it would make noise like it wanted to spin. works fine on all other settings. I replaced the timer and now it gets to spin and just stops. if I move it to another cycle to complete it finishes spin cycle.
