Whirlpool top loader fills only, timer buzzes, won’t advance.
lid switch okay.
Check the pump for an obstruction, the coupling to see if it is broken and jamming things, and see if the tranny turns freely. If all checks out try changing the timer.
— Begin quote from sidfink43;889935
Found the issue. Pinched bare spot on wire at the capacitor bracket. Cap was okay, used an P-clip to replace bracket. Functioning 100% now.
Great, that is such an unusual problem that I didn’t think it could be in the wiring. Glad you got it fixed and thanks for the update, it should help a lot of readers here.
