Washer Fills But Does Nothing Else
While repairing the dryer of this washer/dryer combo, I made the mistake of doing so without unpluging the unit. As a result, some wires that disconecteced from the timer control caused a pretty big short in the area of the timer control. Now the machine only fills. The timer does not advanve nor does the motor spin even if i were to turl the control dial manualy. Should I try replacing the timer first or is there anything I should check first?
Getting F20 error about 75% of the time we run washer. If I unplug it and then plug it back in, it will run fine for one cycle usually. It also seems that if I run a small load I don’t get the F20 error. I’ve checked the intake hoses and screen. thoughts?
