I recently moved my washer out of storage and upon connection discovered that the water floods out of the bottom of the unit (not the exterior drain hose) when it begins to fill. It seems that the water goes into the tub, but then starts to drain - possibly due to a connection underneath or near the bottom that has come loose. However, I can’t figure out how to open the unit up so I can inspect.
Any and all help is appreciated.
GE Model #WHDSR209D5WW
