Washer is almost "dead"
Washer is almost "dead". Motor is not working in any mode. If washer is plugged in it could be filled with water. If it is not plugged in water is not coming in.
In any case the motor is not working.
Is there a fuse on that model? I do not have a manual.
Thank you!!!
Glad you found the problem, good luck with your repair and thanks for updating us. That is very helpful. And thanks for not saying I was wrong in my diagnosis. (Just don’t tell anyone)
