Older Kenmore washer appears "dead"!
Machine stopped while pumping out rinse water.
I manually emptied most of the remaining water.
Checked outlet, has 120v power. When timer is manually advanced, nothing happens. No hum from timer. Checked door switch, it ohmed out okay.
Is there a fuse on the door switch circuit on this model? Would any of the settings function if the timer motor is shot? Do you think the timer needs replaced, or should I keep troubleshooting? Can you tell me which wires on the harness are the power supply? Perhaps it is not getting power to the timer. Do you have any other suggestions I could try before throwing parts at it!!!
Thanks,
Cappy
