washer is level but shakes and moves on spin
hi i recently bought a used washer i used it at my house and it worked fine , then i moved it to my girlfriends , the self level legs in the back did not work they would just go all the way in and they needed to be out about 3/4 of an inch to level the machine . so i bought feet like was in the front of machine, put them on and leveled machine , its level but during spin cycle it shakes and moves across the floor as if it wasnt level. i played with the adjustment of the feet still no good so i need help if you can tell me what it might be i can fix it please help my girl friend is going nuts.
Sounds like something may have become loose or out of place during the move. Take off the front cover and watch it operate and see if you can visually determine the problem with the springs or support system.
i took the front cover off saw nothing loose but i found a piece of rubber about 3/4 of an inch wide and 2 inches long and about an 1/8 inch thick it has a slit in it which im guessing is to hold it in place maybe this is my problem? where does it go? thank you for your help
