Washer Leaking
ive got a GE GHWP1000M0WW washer. it came with the house that we are renting so idk how old it is, or how long its been used. however, it has a brand new drain hose on it. everytime i run a load of clothes, its fine until the final rinse cycle, then it leaks everywhere. if you look on the backside of the washer you can see that it has been spraying from the connection where this hose goes inside the washer. the drain hose actually goes inside and supposedly is supposed to seal but its defiantly not. im not a major appliance tech by no means but i can usually fix this type of stuff. ill post a video that shows how this hooks up incase someone that might have an answer, doesnt understand what im describing. thank you in advance anyone that can help!
https://www.youtube.com/watch?v=rQFjVEmt04Y
If you operate it with the front cover off you can see exactly what the problem is and where it is happening. Don’t understand why it only does it in the rinse cycle, it may be doing it in the wash cycle too and you just don’t notice it.
Anyway run it with front panel off and check to see that the plastic clip that holds the drain hose on is not broken or loose.
