My whirlpool washer leaks during the fill cycle, but only if Large or Super Load size is selected. I have already changed the Water Level switch and it’s rubber tube. Where should I check next.
thanks, Marty
thanks, Marty
I am assuming this is a top loading Whirlpool made direct drive washer.
Take the cabinet off, by pass the lid switch and operate the machine. You should be able to see where it is leaking. This is how we diagnose leaks.
Good luck.
