washer leaks
my washer leaks after washing a load of clothes, the water is clear so is not coming from spinning out. I cant figure out where it is coming from. Any help would be great and yes I have had the washer apart. thanks
— Begin quote from khcoop;264177
Do you have the model number, so we can assist you better.
Did you see any water or water marks inside or on the base of the machine ?
Usually, water on the floor after a cycle is done indicates a drain problem, or a loose fill hose connection, and in some cases a leak from the faucet,unless its a splash over or suds from too much detergent.
You may want to check and varify those possibilities.
Then get us the model number and we can give you a better diagnosis.
