washer motor wont run kicks out on overload suspect capacitor?
Washer will fill but motor will not start, hums and then clicks like circut protection. I suspect the capacitor is bad but unsure of how to check can anyone help?
It is far more likely your motor has failed, but this site
http://www.ehow.com/how_4493634_test-electric-motor-capacitors.html
is one of many that will show you how to test the capacitor.
Be careful, you can get a jolt if it is not discharged when you start working with it.
I would first pull the outer cover, and the pump.Then check for something stuck in the pump.
