Washer Not Spinning
[SIZE=3]Hi,[/SIZE]
[SIZE=3]My washer will fill to desired level but will go no further. I drained the tub and looked under the unit and immediately notice a dangling wire. The wire is white had separated from the wiring harness where the harness connects to the motor switch. A friend suggested I check lid switch and pump. Bypassed the lid switch with no result and checked the pump that I had replaced a few months ago but no noticeable problem there. I then reconnected the broken wire to the wiring harness and plugged back into motor switch. Filled tub and this time the unit hummed but went no further. Over the weekend I picked up a used motor (part number 8529935) with moter switch from a local used appliance dealer but have gone no further.[/SIZE]
