washer only agitates in delicate cycle
Please help. My GE washer will only agitate on the delicate cycle. We usually only use the heavy duty cycle and today it wouldn’t agitate. I tried it on the other cycles and it worked on delicate.
Since it will operate correctly in one setting that suggests there is no mechanical problem with the washer and that the problem is with the control unit.
AP3775089
Before replacing it check all of the wires and connections to make sure something has not come undone.
There is a video that will show you how to change out the timer, and if you buy from this site and the new timer does not fix things you can return it.
