Washer only works in delicate cycle
My Maytag washer model LAT5914AAE only fills, agitates, drains, and spins on delicate cycle. On normal/regular cycle it fills but doesn’t agitate, drain, or spin; the timer however moves along to the end. Thank you for your help!
Hi.
Using the multimeter check if the motor gets 120v between BK and WH wires at the motor switch, timer set on regular.
If no voltage - replace the timer [part]22001252[/part]
If there is 120v - replace the motor [part]12002353 [/part]
Here are the breakdown diagrams and Replacement parts for Maytag LAT5914AAE WASHER-TOP LOADING | AppliancePartsPros.com
Good luck. Post the results.
Simon.
