Washer problems
The washing machine will fill with water, but it will not do anything from there. It will not wash the clothes or move to the other cycles. I put a new timer on it but that did not help. The lid switch is good. Does anyone have any suggestions?
Hi Sam
This really sounds like a lid switch problem. You do not say how you checked it, but the only sure way to do so is to by-pass it and see if the machine will work.
If you have done that and are certain it is ok, then the other things to check are the wiring and the motor switch and motor and the capacitor, although all three are unlikely but possible sources of the problem.
