Washer just fills and will not do anything else
When you start this washer, all it does is fill with water, then nothing. Lid switch is fine. Could it be the timer? Thanks
Sounds like the lid switch. Check for loose screws on the left side lid hinge. That hinge operates the lid switch. You could also jump out the lid switch to rule it out for sure. Otherwise, could be the pressure switch, timer, bad connection at motor…etc.
Eric
