Washer will not fill
The lid safety switch was arcing. Inspection showed frayed wires. Repaired & cleaned wires, checked switch with meter…(OK) replaced sw. Replaced 2 sets of wires. Washer will not fill now. ???
Hard to say, but the lid switch should not stop it from filling. I would guess you have inadvertently disconnected something, so open it up and check out all the connections and wiring. The make sure power is getting to the timer.
