I checked the fuse and it looks to be blown. I have a few.
I replaced the fuse and plugged the washer back in. I did not check the lid switch because I do not recognize the lid switch in the diagram and I do not see a part labelled lid switch.
So I plugged the washer back in and turned on a wash cycle. It was dark and noticed a brief flash. Unplugged the washer again, pulled the fuse and it is blown ;).
How do I check the lid switch? and/or replace it as I do not see it on the diagram.
It was the switch inside the lid-switch assembly. It was stuck down, hence blowing that fuse. I replaced the switch inside the lid-switch assembly and the washer is now working as designed.
