washer will not fill with water
Washer not filling with water. Replaced fill valve, no change. :frowning: The washer runs through all cycles if filled manually with water.
What else should I look at?
Thanks!!
Hi.
Open the control panel and check the lid switch assembly fuse.
If it’s blown - replace the lid switch assembly
22001682
Here are the breakdown diagrams and http://www.appliancepartspros.com/06-top-parts-for-maytag-lat9800aaw.html
Post the results.
Simon.
Simon, the fuse was it! Thank You!!! A good lesson to remember the first thing to check for an electrical problem is any fuse.
Thanks Again!
Peter
You are most welcome.
Simon.
