Washer fills and agitates but does not move past that cycle to drain, rinse and spin . You can hear the timer ticking for a bit after the agitation stops but that soon stops also.
Here’s the breakdown of your unit. http://www.appliancepartspros.com/partsearch/model.aspx?model_id=264445
Start by checking the pump for an obstruction.
Nat
I checked for obstuctions and there were none. I bypassed the lid switch and that was the problem!
There you have it. Good Job!! That’s the way to save the cash. Tom http://www.applianceeducator.com
