I bought my washer used and it has worked great for a few years, but recently I noticed that on occasions when I pull my clothes out they are still dripping wet so I started the spin cycle again and lift the lid and the agitator or drum isn’t moving. This doesn’t happen every load I wash.
When the unit is supposed to be spinning do you hear the motor running?
- No - then its likely the lid switch going bad.
- Yes - then its likely the coupler thats bad
If coupler see part 13
http://www.appliancepartspros.com/brake-clutch-gearcase-parts-for-roper-ras8333rq0.html
If its the lid switch see part 11
http://www.appliancepartspros.com/top-cabinet-parts-for-roper-ras8333rq0.html
