Washer spinning slow not agitating
I have an amana alw880qaw washer that I love. It has recently started spinning so slow it is barely moving so I checked to see if it is agitating and it is not. I have replaced the water pump and the belt abuot 6 months ago. I dont know what part has gone out now so I can fix it again. Any suggestions
Operate it with the front panel off and see if you can tell what is happening, like if the motor is turning or trying to turn but the transmission pulley is not that tells you it is likely in the transmission.
