[SIZE=3][/SIZE]
[SIZE=3]I have a MAYTAG MAV3855AWW washing machine that is spinning slow it also agitates slow.Can someone tell me what’s wrong with it? [/SIZE]
[SIZE=3][/SIZE]
Hi.
The motor on this washer is reversible. By gliding on the motor plate it’s regulating the tension on the belt.More tension - grater the speed.
Check both pulleys, belt, drain pump pulley, motor plate.
The belt isn’t suppose to slip.
Here are the breakdown diagrams and 01-Base & Motor parts for Maytag MAV3855AWW - AppliancePartsPros.com
Post the results.
Simon.
