Washer has broke washer tube dampening strap on the vent/overflow tube side, will this cause water to drain out of tube during washer cycle.
Jay
Jay
Hi.
Check if the water doesn’t leak out on the small and medium size level. If it’s not - then most likely the transmission is spinning and agitating at the same time and need to be replaced.
The transmission WH38X10002
The dampening strap WH1X2727
Thank you.
Simon.
— Begin quote from Simon / APP Team;761566
Hi.
The transmission [part]WH38X10002[/part]
The dampening strap [part]WH1X2727 [/part]
Thank you.
Simon.
Hey Simon,
Thanks for the info, it does it on all water levels, & all wash cycles.
Jay
Check if the tub is spinning in the wash cycle?
Simon.
— Begin quote from Simon / APP Team;761598
Simon.
O.K. Simon will do.
Jay
Simon,
filled tub on all 3 water levels(extra small, medium, extra large)ran thru permanent press on all 3 water levels all the way thru, tub did not spin(swished back & forth), surprisingly didn’t leak anywhere:confused: . So if I can get away with just replacing the dampening straps I’m gonna be estatic:D
. Know, the first time I ran it on the extra small water level the tub acted like it wanted to spin(could this be from it setting up for several months?)but I pushed down on the agitator & it stopped and went to swishing & never tried spinning until spin cycle, Hoping for the best, it’s gonna be a b’day present for my step daughter.
Jay
Pray the Lord, Jay.
Simon.
