washer tub removal
Washer fills does not agitate only spins on perm press, think is spring or ? can not remove nut,spanner off tub to remove tub?
No, It was quiet and I thought I blew a fuse but did not, is a new motor .
I move the knob around and the only responce is on the spin permenent press cycle nothing else works.
I would remove the timer cover and look for burnt contacts. If so, order a new timer AP3019158
I have removed the entire wire harness and all connections and wires look good except one spot on the ground wire a a bit bent. Will it spin in the permanent cycle it the lid switch were bad, otherwise I’m thinking clutch spring?
Top loading Maytag, Washer leaks from out over the top on spin cycle. Spills out on left side top. Any help would be appreciated. Signed,
Still Mopping!
Make sure the tub ring is secure all the way around. (The tub ring seals the inner tub to the outer tub.)
