Washer Watering Issue!!!
Hello Mr. Expert;
I have a Kenmore washer it is working in good condition but now it only working with cold water. I disconnect the hot water hose to make sure there is hot water running and it is. So what part should I replace to bring it back to normal.
Thank you!!!
Jose Mambru
Check the screen inside the hot water side of the valve, could be clogged.
Hi,
I fallowed your recommendation but it did not work out. I removed and cleaned the hot water screen and valve still not working. What can I do next.
Thank you!!!
Jose
