Washer will fill with water won't move to the next cycle
Water will fill properly but won’t move to the next cycle. Can replace part but not for sure if it’s timer or something else.
Will it spin if you move the timer manually?
— Begin quote from Gene;128128
No I tried to move it to different cycles on the timer but nothing would work.
Mike
When the washer is full with water open the control panel and check the water level switch for continuity between the terminals 7 and 16. If no continuity then replace the switch.
Check the lid latch switches according to the [B]wiring diagram[/B].
Check the motor windings.
Post the results.
Here are the breakdown diagrams and replacement parts for the Maytag washer [MODEL]LAT3914AAE[/MODEL]
