Washer will not agitate
My washer will not agitate, motor makes sound like it is trying, but it won’t move. HELP please.
Take off the belt and see if the motor will run with it off. If so, the problem is likely in your transmission. Also check the pump to see if anything is hung up.
Well I don’t know much about washers, what is the pump, where is it? I think the metal thing in the middle under the plastic base is moving, but the base is not moving. It looks like it is not grabbing right, maybe stripped? Spins out fine. I will check the belt and try running it without it. IS there a reset button on the motor somewhere I can try? Thanks so much…
The pump is this part here
AP4373022
but given that it spins out I think the transmission is most likely the problem, in which case a new machine may be in your future.
