The washer performs normally until it reaches the point to drain the tub & spin. It will completely stop then, leaving the tub full of water (and wet clothes).
Advancing the dial does nothing to help, however, at some of the other dial positions, the timer can be heard "humming/buzzing".
Based on the prices of new machines, I would like to repair the old one. Also, since new timers are also expensive, I would like to make sure that I check other possible parts.
So far, all we have done is to manually check every other position of the dial (no help except that the humming noise occurs at some points), and made sure that the lid switch was being contacted by the tab on the lid.
Thanks for any suggestions.
