:)Gibson model GTF1040ASO, fills with water, will drain water but will not spin or agitate. Checked voltage from controller and did not get voltage to motor. What should be replaced?
Inside the lower service panel should be a tech sheet. You will want to first test the speed/motor controller, this part here.
If voltage is getting to that board, try replacing the board.
Thanks for the input. No voltage from controller board, have ordered part today. Thanks! Matt
Okay, the new Main Control Unit should do it.
