Has no power…plug in is good…need advice cannot afford a repair man
[SIZE=3]There are two things you should check. First check the lid switch actuator # 10 on the 5 parts breakdown. To access this you have to remove the front panel then lift the top up. Once up you should see the lid switch actuator. A lot of times the spring will break and this will cause your problem. [/SIZE]
[SIZE=3] [/SIZE]
[SIZE=3]If this is not your problem is most likely the lid switch #3 on that same parts breakdown. [/SIZE]
[SIZE=3][/SIZE]
[SIZE=3][/SIZE]
[SIZE=3]http://www.appliance-repair-it.com/Maytag-washer.html[/SIZE]
