Hi! We have replaced the belts on the washer with new belts and the washer worked fine for about 5 loads. Now it will not spin again. What else could it be? Thanks in advance!
[SIZE=3]A lot of times when people change the belts on this washer they will try to tighten the pump belt by moving the pump to the right. If you did this move it back, the pump belt should be loose. [/SIZE]
[SIZE=3] [/SIZE]
[SIZE=3]Make sure the motor is free to move back and forth on the rollers that it is mounted on. The best way to check this is with the belts off. [/SIZE]
[SIZE=3] [/SIZE]
[SIZE=3]Check those two things and post what you find. [/SIZE]
