washer wont agitate
The washer will fill and it will spin, and empty, but it will not agitate. Instead it makes a loud humming noise from the motor
Pull the outer panel, remove pump and motor and turn the tranny coupler counterclockwise. Check to see if the agitator agitates, if not you have a bad tranny.
