My Roper washer won’t fill with water. When I turn the cycle dial, I can get it to the Spin cycle, but it won’t fill with water. Any suggestions?
it is not normal for the whole valve to go out. so when you turn the water on, you don’t even hear a slight hum? i don’t know where you live, but i was wondering if you washer water lines could be frozen. if not, it is most likely the timer, or the water level switch. tom %url%
