Washer won't fill with cold
My Whirlpool Imperial washing machine recently started just dripping cold water when I washed colors in cold/cold and warm/cold cycles. We took the hose off of the back and tested pressure to see if it was clogged, but that wasn’t the problem. The problem appears to be the mesh "filter" in the orange plastic hookup for the hose. It appears filthy and we think that it’s clogged up. (Hot cycle runs great) Please let me know how to fix/replace this little filter - from removing the back of the washer to where I can find a replacement part.
Thank you!
Please post a complete model number. I will probably recommend you replace in the inlet valve assembly, but let’s see exactly what you have.
