Washer won't fill
Washer will not fill with water. Seems like other functions work. I took off the control knob and it does the same manually. Any suggestions? Thanks!
Hi.
First of all check if the faucets are open and the water is coming through the hoses.
Then with washer set for "fill" check if the water inlet valve solenoids are getting 120VAC.(You would need a multimeter for that).
Next, check for continuity water level switch contacts #7 and #15 (Yel/blk to Brn).
Hre are the breakdown diagrams and Replacement parts for General Electric WLSR2200J5WW WASHER | AppliancePartsPros.com
Thank you. Post the results.
Simon.
