this washer has been fine for a few years but now the washer will go through all cycles except for the final spin to drain the clothes. the clothes are soaked when done. the pump empties the tub but wont spin like it should. PLEASE HELP WIFE BUGGEN
Take off the front panel and inside you should find a tech sheet which will tell you how to put the machine in a test mode and to trouble shoot it. Also, make sure the pump and drain are clear of all debris.
Let us know what you find out, in particular whether the machine will not spin after the wash cycle and the rinse cycle, or if it is just the rinse cycle.
Good luck.
