My washer will not go through the rinse cycle. It runs normal through the wash cycle and stops before draining/rinsing. There is a faint buzzing sound coming from the timer when it is supposed to be rinsing. I can advance the knob through the rinse cycle to the spin cycle and it works fine (drains/spins).
It fills normally with warm or cold so I don’t think a stopped inlet is the problem.
Checked the lid switch and it is fine as well.
Anything else I should check? Does the timer need to be replaced completely or can it be reset? Timer #3953321A.
Thanks much!
