Washer won't spin or agitate
Washer fills, timer runs through cycle but, motor does not start, drain pump starts and drains tub, no spin, timer shuts off.
Lid switch checks good.
Any help would be appreciated.
Ronald40
You have an inverter on the motor that flashes lights for error codes. Use this site
http://www.appliance-repair-it.com/GE-washer-repair.html
to check things out, but the first thing you should do is reset it using the instructions on that site, and check the fuse.
