Washer Won't Spin
This washer has been great - for many years absolutely no problems. Starting yesterday it would not spin. It agitates, rinses, drains. It does everything normally except no spin. When it gets to the spin cycle it sounds normal - no unusual noises. Actually sounds like it is spinning but when you open it up you can see the drum has not moved. Bad lid switch or motor coupling maybe or motor bad altogether? Any ideas on what the problem is? Thanks!
Took machine apart and discovered a borken piece called the driver,brake came (part 64194). Its part of the brake and drive tube. Went to the shop and found a replacement part for it and the machine now appears to work just fine.:slight_smile:
We are glad you were able to fix it. Good job!
