I have a Roper washer that will not spin when in the cycle & it makes a squeaking sound I can turn with my free hand no problem I checked the drainage hose & it is clear. I am also having problem getting the back of to listen to where the noise is coming from I took out 4 screws at the corners but still can’t seem to get it loose. Are other screws holding it in place?
If the motor is turning when in agitation mode and the clutch is not turning when in spin mode you may have problems with the coupling; may not have gone on correctly. Check and see what the motor is doing when it is supposed to be turning, that will give you a good clue as to what is going on.
