Washer Won't Spin
My GE WPSQ3120T9WW washer stopped spinning. It agitates fine. During the spin cycle the pump runs but the motor doesn’t spin. any Ideas?
Check to see that there is nothing jammed in the basket/tub area, and check to see if the pulley will turn in each direction (have the machine unplugged when you do this).
If the motor will not operate, try to trace the current and wiring to the motor with a meter. Check for continuity and for 120v coming to the motor.
